path: root/board/kup/kup4x
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2004-05-12Patch by Klaus Heydeck, 12 May 2004:wdenk
Using external watchdog for KUP4 boards in mpc8xx/cpu.c; load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c; various changes to KUP4 board specific files
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
