path: root/board/kosagi
2016-02-02arm: imx6: Enable DDR calibration on NovenaMarek Vasut
Enable the DDR calibration functionality on Novena to deal with the memory SoDIMM on this board. Moreover, tweak the initial DDR DRAM parameters so the calibration works properly. Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-01arm: imx6: novena, gw_ventana: Fix use of pfuze100 bit definitionsMarek Vasut
The following patch changed the PFUZE100 swbst register bit definitions and broke PMIC configuration on multiple boards, at least on the novena and gw_ventana. This patch fixes it. commit 8fa46350a4c7dca7710362f6c871098557b934ad Author: Peng Fan <Peng.Fan@freescale.com> Date: Fri Aug 7 16:43:45 2015 +0800 power: regulator: add pfuze100 support Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Peng Fan <Peng.Fan@freescale.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Tim Harvey <tharvey@gateworks.com>
2015-11-19input: Support the German keymapSimon Glass
Add support for the German keymap, taken from i8042.c. This can be selected when the input library it initialised. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19input: Add the keycode translation tables separatelySimon Glass
Require the caller to add the keycode translation tables separately so that it can select which ones to use. In a later patch we will add the option to add German tables. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12novena: Remove empty reset_cpu()Fabio Estevam
There is really no need to provide an empty reset_cpu() implementation, so just remove it. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric BĂ©nard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-12-30arm: mx6: novena: Add proper LVDS display supportMarek Vasut
Repair the register configuration and add proper support for the display attached to both LVDS channels. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull video handling into separate fileMarek Vasut
Pull all of the video handling into a separate file, since a lot more code will be added and such code would polute the board file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull GPIO definitions into headerMarek Vasut
Pull the definitions of GPIOs into a separate header file, so that they can be used across all source files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Minor coding style fixMarek Vasut
Just zap multiple spaces and replace them with tabs properly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-20novena: Move the DCD settings to spl codeFabio Estevam
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR. Move the configuration to the spl code. CCM_CCOSR setting is no longer required to get audio functionality in the kernel, so remove such setting. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-11-03novena: Add MAINTAINERS fileFabio Estevam
Commit f91c09acf5c58c ("ARM: mx6: Add support for Kosagi Novena") missed to add a MAINTAINERS file, so add Marek as the maintainer. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-30novena: Fix ethernet PHY reset sequenceNikolay Dimitrov
This patch fixes conflict between PHY pins becoming outputs after reset and imx6 still driving the pins. It also fixes the reset timing as recommended by the PHY datasheet. Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-30ARM: mx6: Add support for Kosagi NovenaMarek Vasut
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Nikolay Dimitrov <picmaster@mail.bg> Reviewed-by: Nikolay Dimitrov <picmaster@mail.bg>
