path: root/board/kosagi/novena/novena.c
2015-12-01arm: imx6: novena, gw_ventana: Fix use of pfuze100 bit definitionsMarek Vasut
The following patch changed the PFUZE100 swbst register bit definitions and broke PMIC configuration on multiple boards, at least on the novena and gw_ventana. This patch fixes it. commit 8fa46350a4c7dca7710362f6c871098557b934ad Author: Peng Fan <Peng.Fan@freescale.com> Date: Fri Aug 7 16:43:45 2015 +0800 power: regulator: add pfuze100 support Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Peng Fan <Peng.Fan@freescale.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Tim Harvey <tharvey@gateworks.com>
2015-11-19input: Support the German keymapSimon Glass
Add support for the German keymap, taken from i8042.c. This can be selected when the input library it initialised. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19input: Add the keycode translation tables separatelySimon Glass
Require the caller to add the keycode translation tables separately so that it can select which ones to use. In a later patch we will add the option to add German tables. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-30arm: mx6: novena: Add proper LVDS display supportMarek Vasut
Repair the register configuration and add proper support for the display attached to both LVDS channels. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull video handling into separate fileMarek Vasut
Pull all of the video handling into a separate file, since a lot more code will be added and such code would polute the board file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull GPIO definitions into headerMarek Vasut
Pull the definitions of GPIOs into a separate header file, so that they can be used across all source files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Minor coding style fixMarek Vasut
Just zap multiple spaces and replace them with tabs properly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-10-30novena: Fix ethernet PHY reset sequenceNikolay Dimitrov
This patch fixes conflict between PHY pins becoming outputs after reset and imx6 still driving the pins. It also fixes the reset timing as recommended by the PHY datasheet. Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-30ARM: mx6: Add support for Kosagi NovenaMarek Vasut
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Nikolay Dimitrov <picmaster@mail.bg> Reviewed-by: Nikolay Dimitrov <picmaster@mail.bg>
