path: root/board/korat
2008-03-27ppc4xx: Updates to Korat-specific codeLarry Johnson
This patch contains updates for changes for the Korat PPC440EPx board. These changes include: (1) Support for "permanent" and "upgradable" copies of U-Boot, as described in the new "doc/README.korat" file; (2) a new memory map for the registers in the board's CPLD; (3) a revised format for manufacturer's data in serial EEPROM; and (4) changes to track updates to U-Boot for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-17Merge Sequoia beautification into Korat codeLarry Johnson
2008-01-04ppc4xx: Use CFG_4xx_GPIO_TABLE to configure Korat boardLawrence R. Johnson
2007-12-27Add support for Korat PPC440EPx boardLarry Johnson
These patches add support for the PPC440EPx-based "Korat" board to U-Boot. They are based primarily on support for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
