path: root/board/kobol
2022-11-07Makefile: Rename u-boot-spl.kwb to u-boot-with-spl.kwbPali Rohár
File name with pattern u-boot-spl* is used on all places except in kwb image for binary with SPL-only code. Combined binary with both SPL and proper U-Boot in other places has file name pattern u-boot-with-spl*. Make it consistent also for kwb image and rename u-boot-spl.kwb to u-boot-with-spl.kwb as this image contains both SPL and proper U-Boot code. Also update documentation about file name changes. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Stefan Roese <sr@denx.de>
2021-07-31arm: mvebu: Load U-Boot proper binary in SPL code based on kwbimage headerPali Rohár
Now that proper load and execution addresses are set in v1 kwbimage we can use it for loading and booting U-Boot proper. Use the new spl_parse_board_header() function to implement parsing the kwbimage v1 header. Use information from this header to locate offset and size of the U-Boot proper binary, instead of using the legacy U-Boot header which is prepended to the U-Boot proper binary stored at fixed offset. This has the advantage that we do not need to relay on legacy U-Boot header anymore and therefore U-Boot proper binary can be stored at any offset, as is the case when loading & booting U-Boot proper by BootROM. The CONFIG_SYS_U_BOOT_OFFS option is therefore not used by SPL code anymore. Also allow to compile U-Boot SPL without CONFIG_SPL_SPI_FLASH_SUPPORT, CONFIG_SPL_MMC_SUPPORT or CONFIG_SPL_SATA_SUPPORT set. In this case BootROM is used for loading and executing U-Boot proper. This reduces the size of U-Boot's SPL image. By default these config options are enabled and so BootROM loading is not used. In some cases BootROM reads from SPI NOR at lower speed than U-Boot SPL. So people can decide whether they want to have smaller SPL binary at the cost of slower boot. Therefore dependency on CONFIG_SPL_DM_SPI, CONFIG_SPL_SPI_FLASH_SUPPORT, CONFIG_SPL_SPI_LOAD, CONFIG_SPL_SPI_SUPPORT, CONFIG_SPL_DM_GPIO, CONFIG_SPL_DM_MMC, CONFIG_SPL_GPIO_SUPPORT, CONFIG_SPL_LIBDISK_SUPPORT, CONFIG_SPL_MMC_SUPPORT, CONFIG_SPL_SATA_SUPPORT and CONFIG_SPL_LIBDISK_SUPPORT is changed from strict to related "imply" (which can be selectivelly turned off and causes booting via BootROM). Options CONFIG_SYS_SPI_U_BOOT_OFFS, CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR and CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET have to to be set to zero as they define the location where kwbimage header starts. It is the location where BootROM expects start of the kwbimage from which it reads, parses and executes SPL part. The same applies to option CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR, which has to be set to one. Update all config files to set correct values of these options and set CONFIG_SYS_U_BOOT_OFFS to the correct value - the offset where U-Boot proper starts. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de>
2021-02-26ddr: marvell: a38x: add support for twin-die combined memory deviceMoti Buskila
commit 6285efb8a118940877522c4c07bd7c64569b4f5f upstream. the twin-die combined memory device should be treatened as X8 device and not as X16 one Signed-off-by: Moti Buskila <motib@marvell.com> Reviewed-by: Kostya Porotchkin <kostap@marvell.com> [ - the default value for twin_die_combined is set to NOT_COMBINED for all boards, as this was default behaviour prior this change ] Signed-off-by: Marek Behún <marek.behun@nic.cz> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-27ARM: mvebu: helios4 adjust env sizes to enable SPI to workDennis Gilmore
mirror the clearfog setup to enable SPI to work Signed-off-by: Dennis Gilmore <dennis@ausil.us>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-21board: mvebu: drop unused ETH_PHY macro definitionsBaruch Siach
These macros are not used anywhere in the boards code. Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08arm: mvebu: helios4: Enable I2C and IO ExpanderAditya Prayoga
Enable Marvell I2C driver and I2C IO expander. Set default bus to external I2C bus. Define I2C aliases in device tree so it can be recognized by the driver. Signed-off-by: Aditya Prayoga <aditya@kobol.io> Reviewed-by: Stefan Roese <sr@denx.de> Tested-By: Dennis Gilmore <dgilmore@redhat.com> Reviewed-By: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-12arm: mvebu: Add Helios4 Armada 38x initial supportDennis Gilmore
The helios4 is built on the SolidRun Armada 38x SOM. The port os based on the ClearFog board, using information from https://github.com/helios-4/u-boot-marvell as well as dtb input from https://github.com/helios-4/linux-marvell Signed-off-by: Dennis Gilmore <dennis@ausil.us> Signed-off-by: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
