path: root/board/kobol
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-21board: mvebu: drop unused ETH_PHY macro definitionsBaruch Siach
These macros are not used anywhere in the boards code. Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08arm: mvebu: helios4: Enable I2C and IO ExpanderAditya Prayoga
Enable Marvell I2C driver and I2C IO expander. Set default bus to external I2C bus. Define I2C aliases in device tree so it can be recognized by the driver. Signed-off-by: Aditya Prayoga <aditya@kobol.io> Reviewed-by: Stefan Roese <sr@denx.de> Tested-By: Dennis Gilmore <dgilmore@redhat.com> Reviewed-By: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-12arm: mvebu: Add Helios4 Armada 38x initial supportDennis Gilmore
The helios4 is built on the SolidRun Armada 38x SOM. The port os based on the ClearFog board, using information from https://github.com/helios-4/u-boot-marvell as well as dtb input from https://github.com/helios-4/linux-marvell Signed-off-by: Dennis Gilmore <dennis@ausil.us> Signed-off-by: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Stefan Roese <sr@denx.de>
