path: root/board/kmc
2021-03-02reset: Remove addr parameter from reset_cpu()Harald Seiler
Historically, the reset_cpu() function had an `addr` parameter which was meant to pass in an address of the reset vector location, where the CPU should reset to. This feature is no longer used anywhere in U-Boot as all reset_cpu() implementations now ignore the passed value. Generic code has been added which always calls reset_cpu() with `0` which means this feature can no longer be used easily anyway. Over time, many implementations seem to have "misunderstood" the existence of this parameter as a way to customize/parameterize the reset (e.g. COLD vs WARM resets). As this is not properly supported, the code will almost always not do what it is intended to (because all call-sites just call reset_cpu() with 0). To avoid confusion and to clean up the codebase from unused left-overs of the past, remove the `addr` parameter entirely. Code which intends to support different kinds of resets should be rewritten as a sysreset driver instead. This transformation was done with the following coccinelle patch: @@ expression argvalue; @@ - reset_cpu(argvalue) + reset_cpu() @@ identifier argname; type argtype; @@ - reset_cpu(argtype argname) + reset_cpu(void) { ... } Signed-off-by: Harald Seiler <hws@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-02ARM: rmobile: Contain CONFIG_ARCH_RMOBILE_BOARD_STRINGMarek Vasut
Pull the symbol from the boards and zap struct rmobile_sysinfo as they are rather useless. The entire purpose of that whole machinery was to print board name in the CONFIG_ARCH_RMOBILE_BOARD_STRING. Do that in a far simpler and more contained manner. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-02-02arm: rmobile: kzm9g: Adjust ETM trace clockTetsuyuki Kobayashi
Set ETM TRCLK down to 78MHz to get clear wave form. This patch makes difference only when you use ETM trace connecting JTAG debugger. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-02-02arm: rmobile: kzm9g: Adjust SDRAM settingTetsuyuki Kobayashi
After stress test, I found some of kzm9g board occures memory failure. This patch adust SDRAM setting. - Enlarge drivability on both SDRAM controller and SDRAM itself - Raise core voltage Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2012-10-16arm: rmobile: kzm9g: enable I2C2Tetsuyuki Kobayashi
Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-16arm: rmobile: kzm9g: enable I2C1Tetsuyuki Kobayashi
Supply clock to I2C1 and release resetting. Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-03arm: rmobile: kzm9g: enable reset commandTetsuyuki Kobayashi
Do soft power on reset in U-Boot reset command. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Modify bus controller setting for CS4Tetsuyuki Kobayashi
Problem: Linux kernel hangs up when it write a file to NFS mounted directory. Solution: Modify bus controller setting for CS4, which connected smsc9221 ethernet controller. Detail: Modify CS4BCR bit[29:28] (IWW[1:0]) from 00 to 01. Modify CS4BCR bit[20:19] (IWRRD[1:0]) from 00 to 01. Modify CS4BCR bit[17:16] (IWRRS[1:0]) from 00 to 01. Modify CS4WCR bit[27:26] (WSW[1:0]) from 10 to 11 Modify CS4WCR bit[25:24] (WHW[1:0]) from 01 to 10 Modify CS4WCR bit[18:16] (WW[2:0]) from 101 to 111 Modify CS4WCR bit[13:11] (SW[2:0]) from 010 to 011 Modify CS4WCR bit[10:7] (WR[3:0]) from 1000 to 1011 Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Adjust low level hardware settingTetsuyuki Kobayashi
Adjust low level hardware setting in s_init. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add supoprt for KMC KZM-A9-GT boardNobuhiro Iwamatsu
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
