path: root/board/keymile
2011-07-28km/common: i2c deblock: enabled print of i2c deblock statusStefan Bigler
Enable printout of i2c deblocking status if chips were in block state or deblocking failed. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-28km/common: add printings to boardid commandsHolger Brunck
Be verbose if do_setboardid was called and print correct names of variables in do_checkboardidhwk. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27powerpc/km82xx: remove 82xx specific functions from common.cHolger Brunck
Common code should be valid for more than one architecture, therefore the km82xx specific code was removed from common.c. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: remove fdt_(gs)et_node_and_valueHolger Brunck
This code is unused and therefore dead code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: move ivm functions from to ivm.cHolger Brunck
The file common.c grows in the past. So move the IVM specific code into an ivm.c file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: remove saveenv from do_checkboardidhwkeyHolger Brunck
This is unneeded here because we save the environment when the board boots the first time. At this time we have set the values already. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: force set ethaddr after reading IVMHolger Brunck
The ethaddr is stored inside the inventory eeprom. During boottime this value was read out and the ethaddr variable was set. Previously this was only done if it ethaddr == NULL but this is wrong for our ARM boards. Because ethaddr is at this stage never NULL for ARM due to the random calculation of a MAC address in mvgbe.c. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: remove obsolete defines and headerHolger Brunck
These defines and the header keymile_hdlc_enet.h are obsolete due to the removed hdlc code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: simplify debug environmentHolger Brunck
The debug environment which is stored in textfiles in the scripts directory was reworked. Two usecase are now present which can be executed simply from the default environment: run develop: this configures the environment to setup the rootfs via nfs run ramfs: this configures the environment to setup the rootfs in ram Each architecture now has a "arch" variable which is used to load the architecture specific debug scripts and to set the rootpath for NFS. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-04arm/km: add support for portl2 boardValentin Longchamp
This adds support for the keymile Kirkwood BEC portl2 board. This board relies on the km_arm (km_kirkwood) BEC. The egiga driver is configured for a 100M full-duplex, A/N off connnection to the backplane. This board has always ethernet present, because it is connected to the marvell switch similar to mgcoge3un. The reset_phy functionality is also the same to mgcoge3un. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: ethernet support for mgcoge3unValentin Longchamp
The phy is also configured with "RGMII clock transitions when data stable" and "Class A driver for the direct backplane connection". Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-05-31arm/km: update mgcoge3un board supportHolger Brunck
We change default settings for egiga on mgcoge3un. The reason we need this is that we have the gig port on mgcoge3un connected using a back-to-back pair of PHYs. There are no magnetics and because of that the port has to be run with a fixd configuration and auto-negotiation must be disabled. In the default mode the egiga driver uses autoneg to determine port speed - which defaults to 1G (we need 100M full duplex). Add wait for the GPIO line connected to mgcoge3ne before starting mgcoge3un. A board specific ethernet present function was added, because on this board ethernet is always present. The BOCO FPGA access was enhanced and changed to use register definitions. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-31arm/km: rename mgcoge2un to mgcoge3unValentin Longchamp
The mgcoge2un target was only an intermediate step to mgcoge3un. For this reason the mgcoge2un support was moved to mgcoge3un, because it isn't needed to support both targets. We add the BootROM init file for the mgcoge3un memphis RAM. We also move the suen3 and suen8 boards into the correct category in the MAINTAINERS file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-31arm/km: introduce bootcount env variable and clean km_armValentin Longchamp
This environment variable is used to set the bootcount address for the kernel. last_stage_init is not available for arm platforms. So the calls to set_km_var and set_bootcount_addr are done in misc_init_r. Additionally some unneeded printouts were removed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-18km/common: simplify default environmentHolger Brunck
This is a first step to simplify the default environment. Move all the environment variables which are only needed for debugging purpose to textfiles in the scripts directory. In case of debugging these files can be loaded via tftp into RAM and set via the env import command. Other variables are identified as obsolete and were removed. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-18km/common: implement boardId HWkey checks as u-boot cmdThomas Herzmann
BoardId and HWKey are used to identify the HW class of a given board. The correct values are stored in the inventory eeprom. During creation time of a boot package the boardId and HWkey for the SW is stored in the default environment and burned into the flash. During boottime the values in the inventory and in the environment are compared to avoid starting of a SW which is not authorized for this board. Some bootpackages are allowed to run on a set of different boardId hwKey. In this case the environment variable boardIdListHex was added to the default environment. In this case the command iterates over the pair values and compares them with the values read from the inventory eeprom. The syntax of such a boardIdListHex value is e.g.: 158_1 159_1 159_2 Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10km/common: implement setboardid commandHolger Brunck
Read out board id and HW key from the IVM eeprom and set these values as an environment variable. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rework DIP switch detectionHuber, Andreas
Introduce a struct for the BFTICU FPGA to increase the readability of the code. And the define CONFIG_SYS_BFTICU_BASE was removed because the CONFIG_SYS_FPGA_BASE is already the base value for BFTICU registers. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rename mgcoge files to km82xxHolger Brunck
The directory and file mgcoge was renamed to km82xx. Because other keymile 82xx will follow and will use the same platform code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: cleanup coding style for mgcoge.cHolger Brunck
2011-05-10km/common: remove hdlc_enet implementationHolger Brunck
The hdlc implementation for mgcoge was initially developed, but later on not used. Remove the C files, the references in mgcoge.c and the Makefile to decrease maintenance effort. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30keymile, common: add setting of some environment variablesHeiko Schocher
This patch adds last_stage_init to all keymile boards. And in the last stage init some environment variables for u-boot were set. Currently these are pnvramaddr, pram and var address. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com>
2011-04-30keymile boards: add CONFIG_PIGGY_MAC_ADRESS_OFFSETHeiko Schocher
Normaly the PIGGY_MAC_ADRESS can be read directly from the IVM on keymile boards. On mgcoge3 it differs. Because there are two piggy boards deployed the second MAC adress must be calculated with the IVM mac adress and an offset. This patch allows to set such a offset in the board config. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de>
2011-04-30arm, keymile: updates for the arm based boards from keymileHeiko Schocher
define KM_IVM_BUS and KM_ENV_BUS macros KM_IVM_BUS is used to define the EEprom_ivm environment variable. These macros allow the reuse of these I2C addresses in other code locations. remove unneeded code On first HW versions the BOCO FPGA was behind a MUX device. These HW versions are not supported anymore. And therefore this code can be removed. added LED initialization for SUEN3 The bootstat LED required to be initialized so to have a green colour after start-up. define CONFIG_SYS_TEXT_BASE This is needed by the relocation code and is not the same for our ARM BEC and thus needs to be defined. remove memsize variable An environment variable for memsize is not needed. this can be get via the board info struct. remove unneeded double access to bi_dram[i].size field Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Luca Haab <luca.haab@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30keymile, common; fix i2c deblocking supportHeiko Schocher
This patch fix the i2c deblocking facility with the i2c HW-Controller. The required delays for byte reading, the enhanced criteria for stop the dummy read and required 5 start/stop sequences are added. Add i2c deblocking before ivm eeprom read. Improve i2c deblocking sequence by respecting stop hold time. Cleaned function for deblocking. Have now one function i2c_make_abort() available for bitbang, mpc82xx and mpc83xx harware controller. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30ppc, 8321: cleanup tuxa1, tuda1 and suvd3 supportHeiko Schocher
For the kmsupx5 a new header file was introduced km8321-common.h. Now the common stuff from tuxa1, tuda1 and suvd3 was removed and the new header file included. The defines CONFIG_SYS_PIGGY_BASE and CONFIG_SYS_PIGGY_SIZE are confusing. Because they actually describe the KMBEC FPGA values. The KMBEC FPGA can be PRIO on kmeter1 or upio on mgcoge. Therefore all the defines were renamed. remove unneeded variable CONFIG_KM_DEF_NETDEV, as it is already declared in keymile-common.h Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30km_arm: change some register values for SDRAM initializationHeiko Schocher
These new values are: - enables UART0 and UART1 pins in MPP - define some L2 cache settings - changes a SDRAM timing to better fit the hardware - removed three writes that were the same as the reset values Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30km-arm: i2c support for suenx based boardsHeiko Schocher
This patch renames the suen3 defines and functions to KM_KIRKWOOD which is more generic and more precise, because these values and functions where used by all suenX boards and not only suen3. Signed-off-by: Lukas Roggli <lukas.roggli@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30ppc: add support for ppc based board mgcoge2neHeiko Schocher
The mgcoge2 board from keymile deploys two different processors. An ARM based Kirkwood for the "unit" part of the SW and a PPC for the "ne" part of the SW. Therefore in Linux and U-Boot the names for the board are mgcoge2un and mgcoge2ne. This patch adds the mgcoge2ne part of the board. The ppc part of mgboge2 is quite similar to mgcoge, therefore a generic header km82xx-common.h was introduced to collect all similiarities. Currently the only difference is that mgcoge2ne has a 64 MB numonyx NOR flash with a single die. The mgcoge has a dual die flash 2*32MB from spansion. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30keymile: Fix Coding style issues for keymile boards.Heiko Schocher
- use I/O accessors -> For accessing the FPGA therefore a struct km_bec_fpga is introduced. - no longer externs needed - to defines, that only select functions, don;t assign a numeric value - Codingstyle changes to prevent checkpatch errors/warnings Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30arm, keymile: rename MACH_SUEN3 to MACH_KM_KIRKWOODHolger Brunck
The MACH_TYPE SUEN3 is now to specific for keymile boards, because other boards similar to suen3 will follow. So the MACH_SUEN3 was renamed to MACH_KM_KIRKWOOD. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-11ppc, mgcoge: add DIP switch detectionAndreas Huber
This reads the DIP switch on mgcoge. The DIP switch is connected to the BFTICU (0x40000089) FPGA. If the DIP switch is set the environment variable 'actual_bank' is set to 0 and starts the SW in bank0. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-04-11arm, keymile: remove unneeded codeHolger Brunck
On first HW versions the BOCO FPGA was behind a MUX device. These HW versions are not supported anymore. And therefore this code can be removed, it is already unused. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-01-18ppc, 8xx: remove obsolete km8xx boards from keymileHolger Brunck
The MPC852 based mgsuvd and kmsupx4 boards from keymile were initially ported but later on not developed further. So the respective files were removed to avoid unneeded merging and maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher<hs@denx.de>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
Conflicts: include/configs/km_arm.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-28kirkwood: get rid of config.mk filesPrafulla Wadaskar
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective board config files, all Marvell kirkwood board have just a single and common entry in their config.mk files: KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg Replace the only reference to KWD_CONFIG in the top level Makefile by an equivalent setting, and remove all kirkwood config.mk files. Signed-off-by: Wolfgang Denk <wd at denx.de> Cc: Prafulla Wadaskar <prafulla at marvell.com> Cc: Siddarth Gore <gores at marvell.com> Cc: Simon Kagstrom <simon.kagstrom at netinsight.net> Cc: Heiko Schocher <hs at denx.de> Cc: Eric Cooper <ecc at cmu.edu> Acked-by: Wolfgang Denk <wd at denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-20arm926ejs, suen3: fix relocation issuesHeiko Schocher
- use internal 2k security SRAM as RAM for early stack. - do early inits in board_init_f() Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2010-09-19ARM: implement relocation for ARM926Heiko Schocher
Change the implementation for arm926 to relocate the code to an arbitrary address in RAM. Adapt the TX25 (i.MX25), magnesium board to test the changes. On the tx25 board TEXT_BASE is set to the final relocation address to prevent one more copying of u-boot code when relocating. More info see: doc/README.arm-relocation da850 board: Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
