renaming the "mgsuvd" board port into "km8xx", because
there come more similar boards from keymile.
Compiling the mgsuvd board with "make mgsuvd_config"
remains.
- activate Rx buf len > 1 on SMC
- pram activated
- MTDPARTS_DEFAULT defined
- update the size of the flash in the DTS
before booting Linux
- MONITOR_LEN updated to 384k
- added CONFIG_HOSTNAME
- added CONFIG_ENV_BUFFER_PRINT
- Environment size reduced to 16k
Check the presence of the PIGGY on the keymile boards mgcoge,
mgsuvd and kmeter1. If the PIGGY is not present, dont register
this Ethernet device.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Signed-off-by: Gary Jennejohn <garyj@denx.de>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
in ft_blob_update () for both boards was an unneccessary
repetition of code, which this patch moves in a common
function for this boards.
The EEprom contains some Manufacturerinformation,
which are read from u-boot at boot time, and saved
in same hush shell variables.
As documented in doc/I2C_Edge_Conditions, adding a
board specific deblocking mechanism via CFG_I2C_INIT_BOARD
for the mgcoge and mgsuvd board.
This code was originally written by Keymile in association
with Anatech and Atmel in 1998. The Code toggels the SCL
until the SCA line goes to HIGH (max. 16 times).
And after this, a start condition is sent.
This is another approach to deblock the I2C Bus. The
soft I2C driver actually sends 9 clocks with SDA High,
and then a stop at the end, to deblock the I2C Bus.
Maybe we should use the approach from Keymile as
the new standard?
There are some more extensions, which are for both boards
and some more boards from this manufacturer will follow soon.
