path: root/board/keymile/km83xx
2011-12-07Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc83xx: powerpc/83xx: fix sdram initialization for keymile boards powerpc/mpc83xx: cleanup makefile for mpc83xx
2011-11-16mpc83xx: km83xx_i2c - fix gcc 4.6 compiler warningKim Phillips
Configuring for kmeter1 board... km83xx_i2c.c: In function 'i2c_make_abort': km83xx_i2c.c:44:8: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-11-11powerpc/83xx: fix sdram initialization for keymile boardsAndreas Huber
commit b11f53f3 (keymile: Fix Coding style issues for keymile boards) introduces a bug according the SDRAM initialization for all km83xx boards. im->ddr.sdram_cfg |= SDRAM_CFG_MEM_EN; was replaced with out_be32(&im->ddr.sdram_cfg, SDRAM_CFG_MEM_EN); and this is wrong, because this overwrites the intial value CONFIG_SYS_DDR_SDRAM_CFG. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-03powerpc/83xx: move km 83xx specific i2c code to km83xx_i2cHolger Brunck
The common code should be valid for more than one architecture. Therefore this code was reorganized and moved to the new file km83xx_i2c.c Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-27km/common: move ivm functions from to ivm.cHolger Brunck
The file common.c grows in the past. So move the IVM specific code into an ivm.c file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-04-30keymile, common: add setting of some environment variablesHeiko Schocher
This patch adds last_stage_init to all keymile boards. And in the last stage init some environment variables for u-boot were set. Currently these are pnvramaddr, pram and var address. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com>
2011-04-30ppc, 8321: cleanup tuxa1, tuda1 and suvd3 supportHeiko Schocher
For the kmsupx5 a new header file was introduced km8321-common.h. Now the common stuff from tuxa1, tuda1 and suvd3 was removed and the new header file included. The defines CONFIG_SYS_PIGGY_BASE and CONFIG_SYS_PIGGY_SIZE are confusing. Because they actually describe the KMBEC FPGA values. The KMBEC FPGA can be PRIO on kmeter1 or upio on mgcoge. Therefore all the defines were renamed. remove unneeded variable CONFIG_KM_DEF_NETDEV, as it is already declared in keymile-common.h Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
