path: root/board/keymile/km83xx/Makefile
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2011-11-03powerpc/83xx: move km 83xx specific i2c code to km83xx_i2cHolger Brunck
The common code should be valid for more than one architecture. Therefore this code was reorganized and moved to the new file km83xx_i2c.c Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-27km/common: move ivm functions from to ivm.cHolger Brunck
The file common.c grows in the past. So move the IVM specific code into an ivm.c file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
