path: root/board/keymile/common
2008-10-18mgcoge, mgsuvd: added support for the IVM EEprom.Heiko Schocher
The EEprom contains some Manufacturerinformation, which are read from u-boot at boot time, and saved in same hush shell variables. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18mgcoge, mgsuvd: add board specific I2C deblocking mechanism.Heiko Schocher
As documented in doc/I2C_Edge_Conditions, adding a board specific deblocking mechanism via CFG_I2C_INIT_BOARD for the mgcoge and mgsuvd board. This code was originally written by Keymile in association with Anatech and Atmel in 1998. The Code toggels the SCL until the SCA line goes to HIGH (max. 16 times). And after this, a start condition is sent. This is another approach to deblock the I2C Bus. The soft I2C driver actually sends 9 clocks with SDA High, and then a stop at the end, to deblock the I2C Bus. Maybe we should use the approach from Keymile as the new standard? Signed-off-by: Heiko Schocher <hs@denx.de>
