path: root/board/keymile/common/ivm.c
2015-02-16KM/IVM: remove ivm_read_eeprom(void)Valentin Longchamp
This is not used anymore since the procedure was split into a simple read function and a later alaysis. The ivm_read_eeprom name is now used for the previous ivm_simple_read_eeprom function. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-16KM/IVM: split the IVM reading and parsing in 2 partsValentin Longchamp
This allows to first read the IVM content (earlier in the boot sequence) and define the ethaddr env variable thanks to the ivm_read_eepromi(). Later, the IVM content can be parsed and used to define some hush variables, when the hush subsystem is available thanks to ivm_analyze_eeprom(). To avoid the HW read to happen twice, the buffer passed to ivm_read_eeprom() has to be reused by ivm_analyze_eeprom (and thus allocated before calling ivm_read_eeprom()). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-06-11board:keymile: remove unnecessary double bracesJeroen Hofstee
Clang interpretes an if condition like "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements. cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-05-29Rename hush to cli_hushSimon Glass
Hush is a command-line interpreter, so rename it to make that clearer. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-10-09Merge branch 'next' of git://git.denx.de/u-boot-mpc83xxTom Rini
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, multibus, keymile: get rid of EEprom_ivm envvariableHeiko Schocher
as the keymile boards use now the new i2c multibus/multiadapter framework, remove the EEprom_ivm Environmentvar, as not longer needed. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-05-21powerpc/83xx/km: make local functions and structs staticHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2013-02-15powerpc/83xx/km: add MV88E6122 switch support for kmvect1Karlheinz Jerg
kmvect1 has a UEC2 connection to the piggy board and a UEC0 connection to the switch MV88E6122. This switch has a connection to a frontport ethernet interface. The ethernet port used for network booting is automatically selected by u-boot. If a Piggy is plugged, the Piggy port is selected (UEC2, eth1). If the Piggy isn't present, the Frontport is selected (UEC0, eth0). The switch reset is connected to a GPIO on the PRIO3 board FPGA (GPIO28) and released at startup. Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: rework piggy mac adress offset generationHolger Brunck
For the the kmvect1 board we will also need a functionality to add an offset to the IVMs MAC address, because these board will have two valid ethernet ports for debugging purpose. So move the code to an own function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: remove CONFIG_SYS_I2C_IVM_BUS related codeHolger Brunck
This define isn't set within our setup files. So we can safely remove the affected code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: remove obsolete codeHolger Brunck
EEprom_ivm_addr isn't set in our environment, so remove the usage of this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2012-09-03km/ivm: fix string len check to support 7 char board namesValentin Longchamp
The fanless boards now have a 7-digit (XXXXX-F) board name. This triggers a border condition when reading this string in the IVM although this string is smaller than the currenly read string size, but only by 1 character. This patch corrects this by changing the size check condition for string length. It is the same change that was done in the platform for this same bug. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Stefan Bigler <stefan.bigler@keymile.com>
2012-06-15km/common: fixed error in ethaddr (1-byte-shift)Thomas Herzmann
The MAC address begins at offset 1. Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-10-22km/common: force set ethaddr only for KM kirkwood boardsHolger Brunck
This prevents u-boot to print out "Can't overwrite "ethaddr"" each time a powerpc board starts. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de>
2011-09-21km/common: fix bug in IVM mac address accessHolger Brunck
The MAC address stored in the inventory eeprom begins at offset 1. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: move ivm functions from to ivm.cHolger Brunck
The file common.c grows in the past. So move the IVM specific code into an ivm.c file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
