path: root/board/kb9202
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-10-05Added support for KwikByte KB920x boards (based on AT91RM9200)Wolfgang Denk
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005
