path: root/board/karo/tx25
2013-05-30tx25: copy SPL directly, not using relocate_code.Albert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Simon Glass <sjg@chromium.org>
2013-05-05imx: tx25: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior, even if some pad control values could probably be simplified. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove unused relocate_code() parametersBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12nand: mxc: Switch NAND SPL to generic SPLBenoît Thébaudeau
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Scott Wood <scottwood@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx25: Clean up lowlevel_initBenoît Thébaudeau
Clean up mx25 lowlevel_init: - Add comments. - Do not use write32 repeatedly with the same value in order not to increase code size. - Make register values configurable. - Use macro parameters with default values instead of literal constants. - Use defined macros instead of duplicating code. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: John Rigby <jcrigby@gmail.com> Cc: Matthias Weisser <weisserm@arcor.de>
2012-09-23KARO TX25: Fix NAND Flash R/W cycle timesBenoît Thébaudeau
The NAND Flash of the KARO TX25 board is a Samsung K9F1G08U0B with 25-ns R/W cycle times. However, the NFC clock for this board was set to 66.5 MHz, so using the NFC driver in symmetric mode (i.e. 1 NFC clock cycle = 1 NF R/W cycle) resulted in NF R/W cycle times of 15 ns, hence corrupted NF accesses. This patch fixes this issue by setting the NFC clock to the highest frequency complying to the 25-ns NF R/W cycle times specification, i.e. 33.25 MHz. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: John Rigby <jcrigby@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Gachet <Daniel.Gachet@hefr.ch> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-02Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: tx25: Use generic gpio_* calls config: Always use GNU ld tools: add kwboot binary to .gitignore file fdt: Include arch specific gpio.h instead of asm-generic/gpio.h serial: CONSOLE macro is not used Conflicts: board/karo/tx25/tx25.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-09-01MX: Set a common gpio.h for all i.MXStefano Babic
Each i.MX has its own gpio.h, defining the same structure. The internal GPIO controller has the same layout (at least for the register used by u-boot) and can be shared. Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Matt Sealey <matt@genesi-usa.com>
2012-09-01tx25: Use generic gpio_* callsVikram Narayanan
Instead of manipulating gpio registers directly, use the calls from the gpio library. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de> Cc: John Rigby <jcrigby@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-08-11tx25: Use generic gpio_* callsVikram Narayanan
2011-11-03MX25: tx25: Fix building due to missing MACH_TYPEStefano Babic
Added MACH_TYPE for the tx25 to the configuration file. The MACH_TYPE is dropped from mach-types.h after last sync with kernel. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-27imx: fix coding styleFabio Estevam
Fix checkpatch warning and errors in several i.MX related files. While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c regarding the usage of extern in a C file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-30MX25: tx25: Avoid the usage of extern in C fileFabio Estevam
Avoid the usage of extern in C file as pointed out by checkpatch. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-12MX25: tx25: Fix build by making use of GPIO frameworkFabio Estevam
Make use of GPIO framework and avoid the following build error: tx25.c: In function 'tx25_fec_init': tx25.c:73: error: dereferencing pointer to incomplete type tx25.c:74: error: dereferencing pointer to incomplete type tx25.c:75: error: dereferencing pointer to incomplete type tx25.c:76: error: dereferencing pointer to incomplete type tx25.c:83: error: dereferencing pointer to incomplete type tx25.c:84: error: dereferencing pointer to incomplete type tx25.c:114: error: dereferencing pointer to incomplete type tx25.c:115: error: dereferencing pointer to incomplete type tx25.c:116: error: dereferencing pointer to incomplete type tx25.c:117: error: dereferencing pointer to incomplete type tx25.c:124: error: dereferencing pointer to incomplete type tx25.c:125: error: dereferencing pointer to incomplete type tx25.c:126: error: dereferencing pointer to incomplete type Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-14imx: Make imx25 compatible to mxc_gpio driver and fix in tx25Matthias Weisser
Adding support for mxc_gpio driver for imx25 and fix names of registers in tx25 board. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-04-27mx25: Make the UART port number explicit in its setup functionFabio Estevam
2010-10-19Merge branch 'elf_reloc'Wolfgang Denk
Conflicts: arch/arm/include/asm/config.h board/LaCie/edminiv2/config.mk board/karo/tx25/config.mk board/logicpd/imx27lite/config.mk doc/README.arm-relocation Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-13arm926ejs, tx25: add support for ELF relocationsHeiko Schocher
2010-09-19ARM: implement relocation for ARM926Heiko Schocher
Change the implementation for arm926 to relocate the code to an arbitrary address in RAM. Adapt the TX25 (i.MX25), magnesium board to test the changes. On the tx25 board TEXT_BASE is set to the final relocation address to prevent one more copying of u-boot code when relocating. More info see: doc/README.arm-relocation da850 board: Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca>
2010-05-05tx25: fix crash while booting LinuxAnatolij Gustschin
Currently booting Linux on TX25 board doesn't work since there is no correct mach-id and boot parameters setup for tx25 board. Fix it now. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: John Rigby <jcrigby@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07Add support for KARO TX25 boardJohn Rigby
This is an i.MX25 base board with only NAND so it uses nand_spl to boot. Signed-off-by: John Rigby <jcrigby@gmail.com> Tune configuration, add support for (redundant) environment in NAND. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> CC: Fred Fan <fanyefeng@gmail.com> CC: Tom <Tom.Rix@windriver.com>
