The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200
Tested on: lite5200b
Note: the fixup functions have not been moved to a common place. This
patch is targeted for immediate merging as in solves a build issue, but
the final name/location of the fixups is still subject to debate. I
propose to merge this now, and move the fixups in the next merge window
to be usable by all targets.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
