path: root/board/ispan
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2006-10-09Coding style cleanupWolfgang Denk
2004-06-10* Patch by Robert Schwebel, 10 Jun 2004:wdenk
Add support for Intel K3 strata flash. * Some cleanup * Patch by Thomas Brand, 10 Jun 2004: Fix "loads" command on DK1S10 board
2004-06-09Patch by Yuli Barcohen, 20 May 2004:wdenk
Add support for Interphase iSPAN boards.
