path: root/board/isee
2016-01-20igep00x0: Cleanup ethernet supportLadislav Michl
- move chip reset to separate function - use CONFIG_SMC911X_BASE instead of hardcoded value - remove unneeded local variable from board_eth_init. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Enric Balletbo Serra <enric.balletbo@collabora.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-11igep00x0: Switch to use the generic distro configuration and environment.Enric Balletbò i Serra
This patch changes a little bit the environment, current environment was broken for a long time, and board don't as expected sometimes, on production systems this is fixed adding boot script. I think it's time to change this to make a system conformant environment and use generic distro configurations and environment instead. We can use a boot script for the old way boot mode. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2015-09-11igep00xx: MAINTAINERS: update eballetbo's email address.Enric Balletbò i Serra
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29OMAP3: igep00x0: Fix boot hang and add support for status LED.Enric Balletbo i Serra
Use the STATUS_LED APIs for indicating a boot progress instead of show_boot_progress. This patch also fixes a problem introduced with commit b3f4ca1135 (dm: omap3: Move to driver model for GPIO and serial). After that commit the board doesn't boot. Looks like the problem is the gpio_request call inside the function show_boot_progress. Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23dm: omap3: Move to driver model for GPIO and serialSimon Glass
Adjust the configuration for the am33xx boards, including beagleboard, to use driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-03-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-03-04mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-18ARM: AM33xx+: Update ioregs to pass different valuesLokesh Vutla
Currently same value is programmed for all ioregs. This is not the case for all SoC's like AM4372. So adding a structure for ioregs and updating in all board files. And also return from config_cmd_ctrl() and config_ddr_data() functions if data is not passed. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Fixup dxr2, cm_t335, adapt pcm051 rev3] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-04am33xx: Stop modifying certain EMIF4D registersTom Rini
Based on the definitive guide to EMIF configuration[1] certain registers that we have been modifying (and are documented registers) should be left in their reset values rather than modified. This has been tested on AM335x GP EVM and Beaglebone White. [1]: http://processors.wiki.ti.com/index.php/AM335x_EMIF_Configuration_tips Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Javier Martinez Canillas <javier@dowhile0.org> Cc: Heiko Schocher <hs@denx.de> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Matt Porter <matt.porter@linaro.org>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-10-07pcm051/igep0033: Supply bd_ram_ofs for cpsw driverLars Poeschel
Since 2bf36ac638ab2db9f0295aa47064976eeebf80c1 the BD ram address is not hardcoded inside cpsw driver any more. Platforms have to supply their bd_ram_ofs in the platform data to the driver. This commit does this for pcm051 and igep0033 boards. Tested-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-10-07ARM: IGEP0033: Update timing to run DDR at 400MHz.Enric Balletbo i Serra
We can run the DDR at 400MHz, so update the timings for that purpose. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
2013-08-28arm, am33xx: add defines for gmii_sel_register bitsHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
2013-08-15am33xx: Stop using PHYS_DRAM_1 defineTom Rini
We defined PHYS_DRAM_1 to 0x80000000 (start of DRAM) and then used this for CONFIG_SYS_SDRAM_BASE. But then we kept on referencing PHYS_DRAM_1 in other places. Change to directly setting CONFIG_SYS_DRAM_BASE and then using that name in code. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15OMAP3: igep00x0: allow booting with a FDT from MMCJavier Martinez Canillas
IGEP boards now have Device Tree support in the mainline kernel. To boot an IGEP board using a DT, a uEnv.txt plain text file could be used to define a custom uenvcmd that will be run by the default boot command. It is more convenient to change the default boot command to allow loading a FDT if it is stored in the boot dir of the rootfs uSD/MMC partition. If no FDT is found then the defaul command tries to boot a zImage without a DT using legacy boot. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
2013-08-15ARM: IGEP0033: Remove CYGNUS name from header.Enric Balletbo i Serra
We will not use CYGNUS names for any IGEP COM based on AM335x processor, so, to avoid confusion, remove from headers. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
2013-08-15ARM: AM33xx: Move s_init to a common placeHeiko Schocher
s_init has the same outline for all the AM33xx based board. So making it generic. This also helps in addition of new Soc with minimal changes. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-08-15ARM: AM33xx: Cleanup clocks layerLokesh Vutla
Cleaning up the clocks layer. This helps in addition of new Soc with minimal changes. This is derived from OMAP4 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-08-15ARM: AM33xx: Cleanup dplls dataLokesh Vutla
Locking sequence for all the dplls is same. In the current code same sequence is done repeatedly for each dpll. Instead have a generic function for locking dplls and pass dpll data to that function. This is derived from OMAP4 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-06-18arm, am33xx: move uart soft reset code to common placeHeiko Schocher
move uart soft reset code to common place and call this function from board code, instead of copy and paste this code for every board. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> [trini: Fix igep0033 build, remove 'regval' on pcm051] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-18arm, am33xx: move rtc32k_enable() to common placeHeiko Schocher
move rtc32k_enable() to common place so all am33xx boards can use it. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-06-05am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.cTom Rini
We need to call the save_omap_boot_params function on am33xx/ti81xx and other newer TI SoCs, so move the function to boot-common. Only OMAP4+ has the omap_hw_init_context function so add ifdefs to not call it on am33xx/ti81xx. Call save_omap_boot_params from s_init on am33xx/ti81xx boards. Reviewed-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-05-10ARM: Add support for IGEP COM AQUILA/CYGNUSEnric Balletbo i Serra
The IGEP COM AQUILA and CYGNUS are industrial processors modules with following highlights: o AM3352/AM3354 Texas Instruments processor o Cortex-A8 ARM CPU o 3.3 volts Inputs / Outputs use industrial o 256 MB DDR3 SDRAM / 128 Megabytes FLASH o MicroSD card reader on-board o Ethernet controller on-board o JTAG debug connector available o Designed for industrial range purposes Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-04-08asm/omap_gpmc.h: consolidate common definesAndreas Bießmann
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate the common parts into a new header. Introduce a new asm/omap_gpmc.h which defines the command part and pulls in the architecture specific one. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-18OMAP3: igep00x0: Add new IGEP COM PROTON.Enric Balletbo i Serra
The IGEP COM PROTON is a new ultra compact module design with an on-board ethernet controller. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-18OMAP3: igep00x0: use official board names.Enric Balletbo i Serra
This trivial patch only changes current boards names for the official names. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-07OMAP3: igep00x0: fix a build warning on IGEP boardsJavier Martinez Canillas
commit b689cd5 OMAP3: use a single board file for IGEP devices introduced the following build warning: igep00x0.h:168:24: warning: backslash-newline at end of file [enabled by default] This patch fixes the issue. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
2013-02-07OMAP3: igep00x0: add boot status GPIO LEDJavier Martinez Canillas
This patch adds an GPIO LED boot status for IGEP boards. The GPIO LED used is the red LED0 while the Linux kernel uses the green LED0 as the boot status. By using different GPIO LEDs, the user can know in which step of the boot process the board currently is. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-07OMAP3: use a single board file for IGEP devicesJavier Martinez Canillas
Even when the IGEPv2 board and the IGEP Computer-on-Module are different from a form factor point of view, they are very similar in the fact that share many components and how they are wired. So, it is possible (and better) to have a single board file for both devices and just use the CONFIG_MACH_TYPE to make a differentiation between each board when needed. This change avoids code duplication by removing 298 lines of code and makes future maintenance easier. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10Pass sdrc timing values through board_sdrc_timings structurePeter Barada
Instead of passing individual registers by value to board_get_mem_timings, pass a board_mem_timings structure pointer for the board files to fill in. Pass same structure pointer to write_sdrc_timings. This saves about 90 bytes of space in SPL. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-09-01OMAP3: fix DRAM size for IGEP-based boards.Enric Balletbò i Serra
The total RAM size of the IGEP-based boards is 512MiB not 1GiB, the LPDDR memory consist on two dies of 256MiB. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
2012-09-01OMAP3: igep00x0: add SPL support for IGEP-based boardsJavier Martinez Canillas
This patch adds SPL support for IGEP-based boards. Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
