path: root/board/isee
2011-09-30OMAP3: Overo: Update GPMC timing for ethernet chipPhilip Balister
The existing timing does not quite meet the minimum requirements in the LAN9221 datasheet. The timing in this patch solves problems noticed on some parts. The patch also combines the CS configuration for the overo and igep0020 boards per request. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-12-17Coding style (white space) cleanup.Wolfgang Denk
2010-11-04ARMV7: OMAP3: Use generic mmc driver on OMAP3 IGEP moduleEnric Balletbo i Serra
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on IGEP v2Enric Balletbo i Serra
2010-11-04ARMV7: OMAP3: IGEP: Rename TEXT_BASESteve Sakoman
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed the IGEP boards since they were just added. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-17OMAP3: Add support for the OMAP3 IGEP module.Enric Balletbo i Serra
The IGEP module is a low-power, high performance production-ready system-on-module (SOM) based on TI's OMAP3 family.The IGEP module solution based upon TI OMAP3 provides a low-power/low-cost platform for a variety of consumer/industrial/medical devices. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: Add support for the IGEP v2 board.Enric Balletbo i Serra
The IGEP v2 board is a low-cost, fan-less and industrial temperature range single board computer that unleashes laptop-like performance and expandability without the bulk, expense, or noise of typical desktop machines. Its architecture shares much in common with other OMAP3 boards. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
