path: root/board/isee/igep00x0
2013-04-08asm/omap_gpmc.h: consolidate common definesAndreas Bießmann
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate the common parts into a new header. Introduce a new asm/omap_gpmc.h which defines the command part and pulls in the architecture specific one. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-18OMAP3: igep00x0: Add new IGEP COM PROTON.Enric Balletbo i Serra
The IGEP COM PROTON is a new ultra compact module design with an on-board ethernet controller. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-18OMAP3: igep00x0: use official board names.Enric Balletbo i Serra
This trivial patch only changes current boards names for the official names. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-02-07OMAP3: igep00x0: fix a build warning on IGEP boardsJavier Martinez Canillas
commit b689cd5 OMAP3: use a single board file for IGEP devices introduced the following build warning: igep00x0.h:168:24: warning: backslash-newline at end of file [enabled by default] This patch fixes the issue. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
2013-02-07OMAP3: igep00x0: add boot status GPIO LEDJavier Martinez Canillas
This patch adds an GPIO LED boot status for IGEP boards. The GPIO LED used is the red LED0 while the Linux kernel uses the green LED0 as the boot status. By using different GPIO LEDs, the user can know in which step of the boot process the board currently is. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-07OMAP3: use a single board file for IGEP devicesJavier Martinez Canillas
Even when the IGEPv2 board and the IGEP Computer-on-Module are different from a form factor point of view, they are very similar in the fact that share many components and how they are wired. So, it is possible (and better) to have a single board file for both devices and just use the CONFIG_MACH_TYPE to make a differentiation between each board when needed. This change avoids code duplication by removing 298 lines of code and makes future maintenance easier. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
