path: root/board/iphase4539/iphase4539.c
2015-01-05mpc8260: remove IPHASE4539 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Grandegger <wg@denx.de>
2002-08-26Initial revisionwdenk
