2006-10-09 | Move "ar" flags to config.mk to allow for silent "make -s" | Wolfgang Denk | |
Based on patch by Mike Frysinger, 20 Jun 2006 | |||
2006-09-01 | Add support for a saving build objects in a separate directory. | Marian Balakowicz | |
Modifications are based on the linux kernel approach and support two use cases: 1) Add O= to the make command line 'make O=/tmp/build all' 2) Set environement variable BUILD_DIR to point to the desired location 'export BUILD_DIR=/tmp/build' 'make' The second approach can also be used with a MAKEALL script 'export BUILD_DIR=/tmp/build' './MAKEALL' Command line 'O=' setting overrides BUILD_DIR environent variable. When none of the above methods is used the local build is performed and the object files are placed in the source directory. | |||
2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2002-03-08 | Initial revision | wdenk | |
