The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Coding style cleanup, update CHANGELOG.
This patch adds support for the board IPEK01 based on the MPC5200.
The Futjitsu Lime graphics controller is configured in 16 bpp mode.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
