path: root/board/ipek01
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-31mpc52xx: add support for the IPEK01 boardWolfgang Grandegger
This patch adds support for the board IPEK01 based on the MPC5200. The Futjitsu Lime graphics controller is configured in 16 bpp mode. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
