2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2003-03-12 | * Patch by Josef Wagner, 12 Mar 2003: | wdenk | |
- 16/32 MB and 50/80 MHz support with auto-detection for IP860 - ETH05 and BEDBUG support for CU824 - added support for MicroSys CPC45 - new BOOTROM/FLASH0 and DOC base for PM826 * Patch by Robert Schwebel, 12 Mar 2003: Fix the chpart command on innokom board * Name cleanup: mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h s/PPCBoot/U-Boot/ in some files s/pImage/uImage/ in some files * Patch by Detlev Zundel, 15 Jan 2003: Fix '' command line quoting * Patch by The LEOX team, 19 Jan 2003: - add support for the ELPT860 board - add support for Dallas ds164x RTC | |||
2002-08-26 | Initial revision | wdenk | |
2002-08-17 | Initial revision | wdenk | |
2002-07-20 | Initial revision | wdenk | |
2001-04-28 | Initial revision | wdenk | |
2000-12-14 | Initial revision | wdenk | |
