This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
[trini: Fixup common/cmd_io.c]
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a,
which changed all occurrences of __bss__end__ into __bss_end,
left behind some untouched __bss_end__ occurrences in all 33
u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and
in board/mousse/u-boot.lds.rom. These are replaced here.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
8xx was left behind when fixing up powerpc linking
scripts to support -fpic.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patch by Murray Jensen, 24 Jun 2003:
- make sure to use only U-boot provided header files
- fix problems with ".rodata.str1.4" section as used by GCC-3.x
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
