path: root/board/iomega
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
