path: root/board/inversepath
2016-07-12usbarmory: Add board_run_command() functionAndrej Rosano
Define a default board_run_command() function. This function contains the commands needed to boot the board when CLI is disabled (CONFIG_CMDLINE=n). Signed-off-by: Andrej Rosano <andrej@inversepath.com>
2015-04-09ARM: mx5: add support for USB armory boardAndrej Rosano
Add support for Inverse Path USB armory board, an open source flash-drive sized computer based on Freescale i.MX53 SoC. http://inversepath.com/usbarmory Signed-off-by: Andrej Rosano <andrej@inversepath.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Chris Kuethe <chris.kuethe@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Vagrant Cascadian <vagrant@debian.org> Tested-By: Vagrant Cascadian <vagrant@debian.org> Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
