path: root/board/intercontrol
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2011-12-12mpc5200: digsy_mtc: Fix extension board detectionAnatolij Gustschin
Switch to extension board detection using pci_find_device() instead of detecting by i2c access to EEPROM device on extension board. This is a cleaner detection method since EEPROM addresses can be different on different board revisions. This also avoids "i2c_read: failed to address chip" error messages in the boot log on boards without extension board which may confuse users. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-04mpc5200: digsy_mtc: fix extension board EEPROM I2C address for rev5Anatolij Gustschin
On newer rev5 hardware the extension board EEPROM I2C address has been changed to 0x54. Make this I2C address configurable depending on CONFIG_DIGSY_REV5 so that extention board presence detection works correctly on newer hardware. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
