path: root/board/intel
2015-08-26x86: crownbay: Enable on-board SMSC superio keyboard controllerBin Meng
So far we only enabled one legacy serial port on the SMSC LPC47m superio chipset on Intel Crown Bay board. As the board also has dual PS/2 ports routed out, enable the keyboard controller which is i8042 compatible so that we can use PS/2 keyboard and mouse. In order to make PS/2 keyboard work with the VGA console, remove CONFIG_VGA_AS_SINGLE_DEVICE. To boot Linux kernel with PIC mode using PIRQ routing table, adjust the mask in the device tree to reserve irq12 which is used by PS/2 mouse. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-14x86: Convert minnowmax to use CONFIG_DM_NETSimon Glass
Move to driver model for networking on minnowmax. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: baytrail: Support operation as an EFI payloadSimon Glass
Disable a few things which interfere with the EFI init. This allows the Minnowboard MAX to boot into EFI, load a U-Boot payload then boot to the U-Boot prompt. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Add Intel Bayley Bay board supportBin Meng
Intel Bayley Bay board is a BayTrail based board. Add this board with existing baytrail fsp support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: minnowmax: Remove smsc47x superio codesBin Meng
On Intel BayTrail SoC, there is a legacy UART (I/O 0x3f8) integrated into the SoC which is enabled by the FSP. Remove the smsc47x superio initialization codes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: minnowmax: initialize the pin-muxing from device treeGabriel Huau
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Remove DECLARE_GLOBAL_DATA_PTR in board filesBin Meng
gd is not referenced in those board files so DECLARE_GLOBAL_DATA_PTR should be removed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Set serial port IRQ for SMSC LPC47MBin Meng
For starting a Linux console on the superio serial port under interrupt mode, the IRQ number must be configured. Signed-off-by: Jian Luo <jian.luo4@boschrexroth.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add basic Intel Galileo board supportBin Meng
New board/intel/galileo board directory with minimum codes, plus board dts, defconfig and configuration files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add support for Intel Minnowboard MaxSimon Glass
This is a relatively low-cost x86 board in a small form factor. The main peripherals are uSD, USB, HDMI, Ethernet and SATA. It uses an Atom 3800 series CPU. So far only the dual core 2GB variant is supported. This uses the existing FSP support. Binary blobs are required to make this board work. The microcode update is included as a patch (all 3000 lines of it). Change-Id: I0088c47fe87cf08ae635b343d32c332269062156 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-13x86: Move CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to KconfigBin Meng
Convert CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to Kconfig options so that we can remove them from board configuration file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: crownbay: Enable Intel E1000 NIC supportBin Meng
We don't have driver for the Intel Topcliff PCH Gigabit Ethernet controller for now, so enable the Intle E1000 NIC support, which can be plugged into any PCIe slot on the Crown Bay board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Add queensbay and crownbay Kconfig filesBin Meng
2014-12-18x86: ich6-gpio: Add Intel Tunnel Creek GPIO supportBin Meng
Intel Tunnel Creek GPIO register block is compatible with current ich6-gpio driver, except the offset and content of GPIO block base address register in the LPC PCI configuration space are different. Use u16 instead of u32 to store the 16-bit I/O address of the GPIO registers so that it could support both Ivybridge and Tunnel Creek. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Add basic support to queensbay platform and crownbay boardBin Meng
Implement minimum required functions for the basic support to queensbay platform and crownbay board. Currently the implementation is to call fsp_init() in the car_init(). We may move that call to cpu_init_f() in the future. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
