path: root/board/intel/bayleybay/bayleybay.c
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-09x86: bayleybay: Convert to use more dm driversBin Meng
Move to driver model for USB and ETH on Intel Bayley Bay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: Add Intel Bayley Bay board supportBin Meng
Intel Bayley Bay board is a BayTrail based board. Add this board with existing baytrail fsp support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
