path: root/board/intel/Kconfig
2017-09-16x86: Support Intel Cherry Hill boardBin Meng
This adds support to Intel Cherry Hill board, a board based on Intel Braswell SoC. The following devices are validated: - serial port as the serial console - on-board Realtek 8169 ethernet controller - SATA AHCI controller - EMMC/SDHC controller - USB 3.0 xHCI controller - PCIe x1 slot with a graphics card - ICH SPI controller with an 8MB Macronix SPI flash - Integrated graphics device as the video console Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-30x86: Add Intel Edison board filesAndy Shevchenko
Add Intel Edison board which is using U-Boot. The patch is based on work done by the following people (in alphabetical order): Aiden Park <aiden.park@intel.com> Dukjoon Jeon <dukjoon.jeon@intel.com> eric.park <eric.park@intel.com> Fabien Chereau <fabien.chereau@intel.com> Felipe Balbi <felipe.balbi@linux.intel.com> Scott D Phillips <scott.d.phillips@intel.com> Sebastien Colleur <sebastienx.colleur@intel.com> Steve Sakoman <steve.sakoman@intel.com> Vincent Tinelli <vincent.tinelli@intel.com> In case we're building for Intel Edison, we must have 4096 bytes of zeroes in the beginning on u-boot.bin. This is done in board/intel/edison/config.mk. First run sets hardware_id environment variable which is read from System Controller Unit (SCU). Serial number (serial# environment variable) is generated based on eMMC CID. MAC address on USB network interface is unique to the board but kept the same all over the time. Set mac address from U-Boot using following scheme: OUI = 02:00:86 next 3 bytes of MAC address set from eMMC serial number This allows to have a unique mac address across reboot and flashing. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> [bmeng: Add MAINTAINERS file for Intel Edison board] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-21x86: Add Intel Cougar Canyon 2 boardBin Meng
This adds basic support to Intel Cougar Canyon 2 board, a board based on Chief River platform with an Ivy Bridge processor and a Panther Point chipset. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: Add Intel Bayley Bay board supportBin Meng
Intel Bayley Bay board is a BayTrail based board. Add this board with existing baytrail fsp support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
