path: root/board/integratorap
2008-01-02Make scripts and Makefiles POSIX compliantWolfgang Denk
The bash builtin versions of the "test" (resp. "[") command allow using "==" for string comparisons, but POSIX compatible implemen- tations (like /usr/bin/test) insist on using "=" only. On such systems you will see: $ /usr/bin/test a == a && echo OK /usr/bin/test: ==: binary operator expected This patch fixes Makefiles and scripts to use POSIX style. Signed-off-by: Wolfgang Denk <wd@denx.de>
2005-10-09Cleanup warnings for cpu/arm720t & cpu/arm1136 files.Wolfgang Denk
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005
2005-10-06CleanupWolfgang Denk
2005-10-06Make "split_by_variant.sh" executable.Wolfgang Denk
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Update multicore CM9XX support for Integrator AP to allow booting from flashWolfgang Denk
Patch by Jean-Paul Saman, 8 Feb 2005
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-07-11* Patch by Philippe Robin, 01 Jul 2004:wdenk
Add initialization for Integrator and versatile board files. * Patch by Hinko Kocevar, 01 Jun 2004: Fix VFD FB allocation, add LCD FB allocation on ARM
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
