2009-01-29 | move ARM Ltd. to vendor dir | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2006-09-01 | Add support for a saving build objects in a separate directory. | Marian Balakowicz | |
Modifications are based on the linux kernel approach and support two use cases: 1) Add O= to the make command line 'make O=/tmp/build all' 2) Set environement variable BUILD_DIR to point to the desired location 'export BUILD_DIR=/tmp/build' 'make' The second approach can also be used with a MAKEALL script 'export BUILD_DIR=/tmp/build' './MAKEALL' Command line 'O=' setting overrides BUILD_DIR environent variable. When none of the above methods is used the local build is performed and the object files are placed in the source directory. | |||
2004-03-14 | Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340 | wdenk | |
2004-03-14 | * Patch by Philippe Robin, 09 Mar 2004: | wdenk | |
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC |
