path: root/board/innokom/config.mk
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
