path: root/board/inka4x0
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-14powerpc: inka4x0: convert to generic boardAnatolij Gustschin
Also update maintainer info. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2014-01-24board: delete unused header filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-02-04ppc: Move mpc5xxx clocks to arch_global_dataSimon Glass
Move ipb_clk and pci_clk into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-12-09Move LDSCRIPT definitions to board config files.Wolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only LDSCRIPT definitions. Move these into th respective board config files and remove the now empty config.mk files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Detlev Zundel <dzu@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Detlev Zundel < dzu@denx.de> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher<hs@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Remove board-specific command table relocation fixupsPeter Tyser
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-05-15powerpc/inka4x0: Remove left-over ide reset code.Detlev Zundel
The pin which was used in preliminary versions of the board for ide reset is really connected to the rtc clock. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-30inka4x0: Use proper accessor macros for memory mapped registers.Detlev Zundel
2009-03-30inka4x0: Add hardware diagnosis and RTC in configuration.Detlev Zundel
This patch adds the board specific communication routines needed by the external 4543 RTC. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-30inka4x0: Add hardware diagnosis functions for inka4x0Detlev Zundel
This patch adds advanced diagnosis functions for the inka4x0 board. Signed-off-by: Andreas Pfefferle <ap@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-01-25inka4x0: remove dead codeWolfgang Denk
2007-11-15[INKA4x0] NG hardware: flash supportMarian Balakowicz
Disabled and remove inka4x0 custom flash driver, use CFI flash driver instead. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: SDRAM supportMarian Balakowicz
Add support for three new DDR chips that may be present on a NG INKA4x0 hardware: HYB25D512160BF-5, K4H511638C-7CB3, T46V32M16BN-6IT. Cleanup board/inka4x0/mt48lc16m16a2-75.h file. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: platform code updateMarian Balakowicz
- Cleanup compile warnings. - Add missing '\0' in default environment. - Increase CFG_MONITOR_LEN to 256 KiB. - Add required CFG_USE_PPCENV. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-04Remove obsolete mpc5xxx linker scripts (3 of 3)Grant Likely
2007-07-04Consolidate mpc5xxx linker scriptsGrant Likely
2006-11-01- Add MPC5XXX register definition MPC5XXX_WU_GPIO_DATA_I and change theBartlomiej Sieka
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with MPC5XXX_WU_GPIO_DATA_O for affected boards. - Add defintions for some MPC5XXX GPIO pins.
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-03-14INKA4x0: Allow initialization of LCD backlight dimming fromwdenk
"brightness" environment variable.
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
