path: root/board/inka4x0
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Remove board-specific command table relocation fixupsPeter Tyser
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-05-15powerpc/inka4x0: Remove left-over ide reset code.Detlev Zundel
The pin which was used in preliminary versions of the board for ide reset is really connected to the rtc clock. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-30inka4x0: Use proper accessor macros for memory mapped registers.Detlev Zundel
2009-03-30inka4x0: Add hardware diagnosis and RTC in configuration.Detlev Zundel
This patch adds the board specific communication routines needed by the external 4543 RTC. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-30inka4x0: Add hardware diagnosis functions for inka4x0Detlev Zundel
This patch adds advanced diagnosis functions for the inka4x0 board. Signed-off-by: Andreas Pfefferle <ap@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-01-25inka4x0: remove dead codeWolfgang Denk
2007-11-15[INKA4x0] NG hardware: flash supportMarian Balakowicz
Disabled and remove inka4x0 custom flash driver, use CFI flash driver instead. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: SDRAM supportMarian Balakowicz
Add support for three new DDR chips that may be present on a NG INKA4x0 hardware: HYB25D512160BF-5, K4H511638C-7CB3, T46V32M16BN-6IT. Cleanup board/inka4x0/mt48lc16m16a2-75.h file. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: platform code updateMarian Balakowicz
- Cleanup compile warnings. - Add missing '\0' in default environment. - Increase CFG_MONITOR_LEN to 256 KiB. - Add required CFG_USE_PPCENV. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-04Remove obsolete mpc5xxx linker scripts (3 of 3)Grant Likely
2007-07-04Consolidate mpc5xxx linker scriptsGrant Likely
2006-11-01- Add MPC5XXX register definition MPC5XXX_WU_GPIO_DATA_I and change theBartlomiej Sieka
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with MPC5XXX_WU_GPIO_DATA_O for affected boards. - Add defintions for some MPC5XXX GPIO pins.
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-03-14INKA4x0: Allow initialization of LCD backlight dimming fromwdenk
"brightness" environment variable.
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2005-01-31* Update CPC45 board configuration.LABEL_2005_01_31_2245wdenk
* Add USB and PCI support for INKA4x0 board
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-16Code cleanup.wdenk
2004-12-16Add support for INKA4X0 boardwdenk
