2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2003-03-27 | * Add support for MIPS32 4Kc CPUs | wdenk | |
* Add support for INCA-IP Board |
