path: root/board/in-circuit
2013-10-31avr32: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2012-06-04avr32:grasshopper: fix PHY initialisationAndreas Bießmann
2011-08-03avr32: add grasshopper (ICnova AP7000) boardAndreas Bießmann
The grasshopper board is a neat avr32 evaluation kit produced by In-Circuit GmbH. See http://www.ic-board.de/product_info.php?info=p75_ICnova-AP7000-Base.html for detailed information about this device. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
