path: root/board/imgtec
2013-11-26malta: enable PIIX4 SERIRQPaul Burton
Whilst U-boot does not require this itself, Linux currently relies upon it having been muxed and enabled by the bootloader. Thus in order to preserve compatibility with current kernels before a fix is merged in Linux we will enable the SERIRQ interrupt and mux it to its pin. Without doing this current kernels will never receive serial port interrupts and the end result is typically that userland appears to hang. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: add script & instructions to flash U-bootPaul Burton
This patch adds a script which may be used with MIPS Navigator Console and a MIPS Nagivator Probe in order to flash U-boot to a MIPS Malta development board. Please see the newly added doc/README.malta for usage instructions. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup PIIX4 interrupt routePaul Burton
Without setting up the PIRQ[A:D] interrupt routes, PCI interrupts will be left disabled. Linux does not set up this routing but relies upon it having been set up by the bootloader, reading back the IRQ lines which the PIRQ[A:D] signals have been routed to. This patch routes PIRQA & PIRQB to IRQ 10, and PIRQC & PIRQD to IRQ 11. This matches the setup used by YAMON. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: enable RTC supportPaul Burton
This is actually required in order for a Linux kernel to boot successfully on a physical Malta board. Without enabling the RTC, a Malta Linux kernel will get stuck in its estimate_frequencies function on boot. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: disable L2 cachesPaul Burton
Malta boards may be used with cores which support L2 caches, however U-boot does not yet support L2 cache for MIPS. Thus for the moment we'll disable L2 caches by setting the L2B bit in Config2. This is specific to MTI/Imagination MIPS cores which is why this is done for the Malta board rather than generically. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: display "U-boot" on the LCD screenPaul Burton
Displaying a message on the LCD screen is a simple yet effective way to show the user that the board has booted successfully. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup super I/O UARTsPaul Burton
On a real Malta the Super I/O needs to be configured before we are able to access the UARTs. This patch performs that configuration, setting up the UARTs in the same way that YAMON would. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09qemu-malta: rename to just "malta"Paul Burton
This is in preparation for adapting this board to function correctly on a physical MIPS Malta board. The board is moved into an "imgtec" vendor directory at the same time in order to ready us for any other boards supported by Imagination in the future. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
