path: root/board/imgtec
2020-07-28Makefile: Rename ALL-y to INPUTS-ySimon Glass
When binman is in use, most of the targets built by the Makefile are inputs to binman. We then need a final rule to run binman to produce the final outputs. Rename the variable to indicate this, and add a new 'inputs' target. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-02common: Move pci_init_board() out of common.hSimon Glass
This function can be dropped when all boards use driver model for PCI. For now, move it into init.h with a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move board_get_usable_ram_top() out of common.hSimon Glass
Move this function into init.h which seems to be designed for this sort of thing. Also update the header to declare struct global_data so that it can be included without global_data.h being needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set_ulong() to env.hSimon Glass
Move env_set_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-12-19mips: jz47xx: Add Creator CI20 platformPaul Burton
Add support for the Creator CI20 platform based on the JZ4780 SoC. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Marek Vasut <marex@denx.de>
2018-07-20board/imgtec/boston: Add new defconfigs to the MAINTAINERS listTom Rini
2018-01-25boston: Pad binary in .mcs to a multiple of 16 bytesPaul Burton
When flashing U-Boot on a Boston board using Xilinx Vivado tools, the final 0x00 byte which ends the .relocs section seems to be skipped & left in flash as 0xff unless the data contained in the .mcs is padded out to a 16 byte boundary. Without our final zero byte relocation will fail with an error about a spurious reloc: Avoid this problem by padding out the data in the .mcs file to a 16 byte boundary using srec_cat's -range-pad functionality. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-11-28boston: Add u-boot.mcs make targetPaul Burton
U-Boot is generally flashed to a MIPS Boston development board by means of a .mcs file which Xilinx Vivado software can write to the flash present on the board. As such we'd generally want to produce an mcs file when building U-Boot to target the Boston board. Introduce a make target for u-boot.mcs which generates it using the srec_cat tool available from the SRecord project, and build it by default when srec_cat is present. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2017-11-28Update Paul Burton's email addressPaul Burton
MIPS is no longer a part of Imagination Technologies, and as such my @imgtec.com email address will soon cease to function. This patch updates occurrances of it with my new @mips.com email address, and adds an entry in .mailmap such that git (& tools such as get_maintainer.pl when examining history) will use the new address. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de
2017-11-28boston: Remove unused label in lowlevel_displayPaul Burton
The lowlevel_display() function includes a "1:" label which is never used. Remove it. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-11-28boston: Drop unused return valuePaul Burton
The boston lowlevel_init() function zeroes the return register v0, despite the function not being expected to return a value & that value never being used. Remove the redundant assignment to v0. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-05-12boston: Setup memory ranges in FDT provided to LinuxPaul Burton
The boston memory map isn't suited to the simple "all memory starting from 0" approach that the MIPS arch_fixup_fdt() implementation takes. Instead we need to indicate the first 256MiB of DDR from 0 and the rest from 0x90000000. Implement ft_board_setup to do that. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-12-09imgtec: Update MAINTAINERS for more config filesTom Rini
Cover all of the boston and malta variations. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-21boston: Introduce support for the MIPS Boston development boardPaul Burton
This patch introduces support for building U-Boot to run on the MIPS Boston development board. This is a board built around an FPGA & an Intel EG20T Platform Controller Hub, used largely as part of the development of new CPUs and their software support. It is essentially the successor to the older MIPS Malta board. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-21MIPS: Malta: Enable CM & L2 supportPaul Burton
Enable support for the MIPS Coherence Manager & L2 caches on the MIPS Malta board, removing the need for us to attempt to bypass the L2 during boot (which would fail with recent CPUs that expose L2 config via the CM anyway). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-09-21mips: Add MIPSfpga platform supportZubair Lutfullah Kakakhel
MIPSfpga is an FPGA based dev platform. In a nutshell, its a microAptiv cpu core with lots of Xilinx IP blocks The FPGA dev board used is the Nexys4DDR board by Digilent. For more information, check the Readme file in board/imgtec/xilfpga Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-31malta: Allow MIPS64 buildsPaul Burton
Both real Malta boards & emulators that mimic Malta (eg. QEMU) can support MIPS64 CPUs. Allow MIPS64 builds of U-Boot for such boards, which enables the user to make use of the whole 64 bit address space. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26malta: Tidy up UART address selectionPaul Burton
The address of the UART differs based upon the system controller because it's actually within the I/O port region, which is in a different location for each system controller. Rather than handling this as 2 UARTs with the correct one selected at runtime, use I/O port accessors for the UART such that access to it gets translated into the I/O port region automatically. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-21malta: Remove ".set mips32" directivePaul Burton
We always build for a mips32 or higher ISA, so this ".set mips32" directive is redundant. Once MIPSr6 support is added it will become harmful since some instruction encodings change & this directive will cause the older encodings to be incorrectly emitted instead of the appropriate ones for the build. In preparation for supporting MIPSr6, remove this redundant directive. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-01malta: Use I/O accessors for SuperI/O controllerPaul Burton
Rather than passing the I/O port base address to the Super I/O code, switch it to using outb such that it makes use of the I/O port base address automatically. Drop the extern keyword to satisfy checkpatch whilst here. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-02-01malta: Set I/O port base earlyPaul Burton
Set the I/O port base earlier, from board_early_init_f, in preparation for it being used by the serial driver. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-01-16MIPS: malta: fix IO accessor callDaniel Schwierzeck
Use void pointer as address argument for readl(). This is required for the upcoming MIPS asm header file and I/O accessor update. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-01-29malta: delay after resetPaul Burton
Reset isn't instant, so delay to give it a chance. Otherwise we go on to print a failure message before resetting anyway. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-01-29malta: IDE supportPaul Burton
This patch adds IDE support to the MIPS Malta board. The IDE controller is enabled after probing the PCI bus and otherwise just makes use of U-boot generic IDE support. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-01MIPS: kconfig: globally define CONFIG_SYS_CPU for MIPSDaniel Schwierzeck
Now the user can select the CPU type for each target. Thus CONFIG_SYS_CPU could be set globally. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-11-26malta: enable PIIX4 SERIRQPaul Burton
Whilst U-boot does not require this itself, Linux currently relies upon it having been muxed and enabled by the bootloader. Thus in order to preserve compatibility with current kernels before a fix is merged in Linux we will enable the SERIRQ interrupt and mux it to its pin. Without doing this current kernels will never receive serial port interrupts and the end result is typically that userland appears to hang. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: add script & instructions to flash U-bootPaul Burton
This patch adds a script which may be used with MIPS Navigator Console and a MIPS Nagivator Probe in order to flash U-boot to a MIPS Malta development board. Please see the newly added doc/README.malta for usage instructions. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup PIIX4 interrupt routePaul Burton
Without setting up the PIRQ[A:D] interrupt routes, PCI interrupts will be left disabled. Linux does not set up this routing but relies upon it having been set up by the bootloader, reading back the IRQ lines which the PIRQ[A:D] signals have been routed to. This patch routes PIRQA & PIRQB to IRQ 10, and PIRQC & PIRQD to IRQ 11. This matches the setup used by YAMON. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: enable RTC supportPaul Burton
This is actually required in order for a Linux kernel to boot successfully on a physical Malta board. Without enabling the RTC, a Malta Linux kernel will get stuck in its estimate_frequencies function on boot. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: disable L2 cachesPaul Burton
Malta boards may be used with cores which support L2 caches, however U-boot does not yet support L2 cache for MIPS. Thus for the moment we'll disable L2 caches by setting the L2B bit in Config2. This is specific to MTI/Imagination MIPS cores which is why this is done for the Malta board rather than generically. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: display "U-boot" on the LCD screenPaul Burton
Displaying a message on the LCD screen is a simple yet effective way to show the user that the board has booted successfully. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: setup super I/O UARTsPaul Burton
On a real Malta the Super I/O needs to be configured before we are able to access the UARTs. This patch performs that configuration, setting up the UARTs in the same way that YAMON would. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
