path: root/board/ids8247
2007-12-07Convert boards that set memory node to use fdt_fixup_memory()Kumar Gala
2007-12-07Fix build breakage due to libfdt importKumar Gala
The IDS8247 got lost in the update and need an API update do to rename of functions in libfdt. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-03changes for IDS8247 board supportSergej Stepanov
To get the IDS8247 board working following are done: - FCC2 is deactivated - FCC1 is activated - I2C is activated - CFI driver is activated - Adapted for use with LIBFDT Signed-off-by: Sergej Stepanov <Sergej.Stepanov@ids.de> --
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[f-l]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc824x linker scripts (2 of 4)Grant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
