path: root/board/ids/ids8313/ids8313.c
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-04-23mpc83xx: add ids8313 supportHeiko Schocher
add support for the ids8313 board. CPU: e300c3, MPC8313, Rev: 2.1 at 396 MHz, CSB: 132 MHz I2C: ready SPI: ready DRAM: 128 MiB (DDR2, 32-bit, ECC off, 264 MHz) Flash: 8 MiB NAND: 128 MiB Net: TSEC0, TSEC1 [PRIME] public key on NOR flash start Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
