path: root/board/icpdas/lp8x4x
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-18arm: pxa: init ethaddr for LP-8x4x using DTSergei Ianovich
When DT define aliases for etherner0 and ethernet1, U-Boot automatically patched MAC addresses using ethaddr and eth1addr environment variables respectively. Custom initialization is no longer needed. Signed-off-by: Sergei Ianovich <ynvich@gmail.com> CC: Marek Vasut <marex@denx.de>
2013-12-18arm: pxa: fix LP-8x4x USB supportSergei Ianovich
2013-10-20usb: rename board_usb_init_type to usb_init_typeTroy Kisky
This will be used by usb_lowlevel_init so it will no longer be used by only board specific functions. Move definition of enum usb_init_type higher in file so that it will be available for usb_low_level_init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-06-12arm: pxa: Add support for ICP DAS LP-8x4xSergey Yanovich
LP-8x4x is a programmable automation controller by ICP DAS. It is shipped with outdated U-Boot v1.3.0 This patch adds enough supports to boot the board: - 128M of 128M SDRAM - 32M of 48M NOR Flash memory - 1 of 4 Serial consoles (PXA FFUART) - 2 of 2 Ethernet controllers (DM9000) Signed-off-by: Sergey Yanovich <ynvich@gmail.com> Series-to: u-boot Series-cc: marex
