path: root/board/hymod
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-11-22common: move extern char console_buffer[] to common.hIgor Grinberg
Extract all extern declarations for console_buffer[] out of c files into the common.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-11-07board/hymod/input.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: input.c: In function 'hymod_get_ethaddr': input.c:79:10: warning: variable 'ea' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-10-26net: tftpput: Rename TFTP to TFTPGETSimon Glass
This is a better name for this protocol. Also remove the typedef to keep checkpatch happy, and move zeroing of NetBootFileXferSize a little earlier since TFTPPUT will need to change this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2011-05-12MPC8260: Fix compile problems with "hymod" boardWolfgang Denk
Commit 9d8fbd1 "powerpc, 8xx: Fixup all 8xx u-boot.lds scripts" broke building of the MPC8260 based "hymod" board. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Cc: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2007-11-15Revert "Correct fixup relocation for mpc8260"Grant Likely
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[f-l]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Correct fixup relocation for mpc8260Grant Likely
2007-07-04Consolidate mpc8260 linker scriptsGrant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
