path: root/board/htkw/mcx
2016-09-23treewide: use #include <...> to include public headersMasahiro Yamada
We are supposed to use #include <...> to include headers in the public include paths. We should use #include "..." only for headers in local directories. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-09mcx: update maintainer and convert to generic boardAnatolij Gustschin
Remove obsolete email address from MAINTAINERS. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tom Rini <trini@konsulko.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-02-21omap3: fix pinmux for mcx boardStefano Babic
New hardware version cannot recognize the SD-Card because the SYS_NRESWARM, set as GPIO, does not guarantee the required reset time. Change the pin function back to enable the SYS_NRESWARM signal driven by the SOC. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-10-20usb: ehci-hcd: add enum usb_init_type parameter to ehci_hcd_init.Troy Kisky
This paramter will later be used to initialize OTG ports in host or device mode. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-06-10ARM: OMAP2+: Rename asm/arch/clocks.h asm/arch/clock.hLokesh Vutla
To be consistent with other ARM platforms, renaming asm/arch-omap*/clocks.h to asm/arch-omap*/clock.h Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-03-08omap3: allow dynamic selection of gfx_formatNikita Kiryanov
Currently, omap3_dss_panel_config() sets gfx_format to a value that is hardcoded in the code. This forces anyone who wants to use a different gfx_format to make adjustments after calling omap3_dss_panel_config(). This could be avoided if the value of gfx_format were parameterized as input for omap3_dss_panel_config(). Make gfx_format a field in struct panel_config, and update existing structs to set this field to the value that was originally hard coded. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-25OMAP3: add video support to the mcx boardStefano Babic
Add video support to the board with the display focaltech etm070003dh6. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-25OMAP3: mcx: updated to new hardware revisionStefano Babic
Some GPIOs differ in the new revision board. Previous revision are considered obsolete and they will not anymore supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-25OMAP3: updated pinmux and environment for new revision of mcx boardStefano Babic
The mcx board was slightly modified and the pinmux must be updated. There is no need to support the old board, that becomes obsolete. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-15usb: ehci: rework to take advantage of new lowlevel interfaceLucas Stach
Kill off ehci-core.h It was used to specify some static controller data. To support more than one controller being active at any time we have to carry the controller data ourselfes. Change the ehci interface accordingly. NOTE: OMAP implemented the ehci stuff a bit backwards and should be fixed to do the same thing as other platforms. But the change for now is at least compile clean. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-01OMAP3: mcx: read hot-water-button after resetStefano Babic
Detect hot-water-button to start a differnt image. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@ti.com>
2012-09-01OMAP3: mcx: set pinmux for uart4Stefano Babic
2012-05-15omap3: Introduce weak misc_init_rTom Rini
Introduce a __weak misc_init_r function that just runs dieid_num_r(). Remove misc_init_r from cm_t35, mcx, omap3_logic and mt_ventoux as this was all they did for misc_init_r. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
