path: root/board/hmi1001
2008-03-18HMI1001: fix compile problem.Wolfgang Denk
2008-03-13HMI1001: add support for MPC5200 Rev. B processors.Wolfgang Denk
2007-07-04Remove obsolete mpc5xxx linker scripts (3 of 3)Grant Likely
2007-07-04Consolidate mpc5xxx linker scriptsGrant Likely
2007-03-07HMI1001: fix build error, cleanup compiler warnings.Wolfgang Denk
2005-09-03Cleanup compiler warnings.Wolfgang Denk
2005-08-30Add keyboard and dot matrix display support for HMI1001 board.Wolfgang Denk
2005-08-16Enable PCI on hmi1001 boardWolfgang Denk
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
