This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
* Disable "date" and "sntp" commands on TQM866M which has no RTC
