path: root/board/highbank/ahci.c
2017-07-11dm: ahci: Rename struct ahci_probe_entSimon Glass
This is not a very useful name since once it is probed it still hangs around. With driver model we will use uclass data for this, so rename the struct. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-15highbank: add custom ahci_link_up functionMark Langsdorf
The Calxeda highbank SOC needs a custom sequence to bring up SATA links, so override ahci_link_up with custom function to handle combophy setup. Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Richard Gibbs Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
