path: root/board/hermes
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
2002-08-26Initial revisionwdenk
2001-04-28Initial revisionwdenk
2000-12-14Initial revisionwdenk
